VGC V2S
bigplant
VGC V2S
I have a VGC V2S which I want to connect to my HDMI tv, but I cannot work out what I need to do. Can anybody help please?
Hi bigplant and welcome to Club Vaio.
Unfortunately, your Vaio is designed as an "all-in-one" solution. It has no connection that can export a video signal.
You will need an external video card LIKE THIS ONE that will connect to your USB port. It can import and export composite video.
As it is an analogue signal, the quality will be lower than using your Vaio's screen. I do not think you can get a digital video signal from your Vaio to your TV.
:slight_frown:
