VGN A217M BIOS Udate
christian78
Hi !
Does anybody know about a BIOS UDATE for VAIO VGN A217M !
I don't find it in the VAIO LINK Site !
Please HELP I have keyboard Problems with my VAIO !
Thank's CHRIS !
10 REPLIES 10
Hi Chris,
If you can't find a BIOS update HERE then there probably isn't one.
If you could be a bit more specific about your keyboard problem there may be another solution.
:thinking:
christian78
Hi Blencogo !
This is my problem:
When I start my system ( Windows Prof. with service Pack 2 )
many keys doesn't work !
After an half hour some keys works but not the arrow keys !
The arrow keys will never work any time !
I don't know what's the Problem ?!
Thank's for helP, Chris !
kee-lo_
Sounds like a dodgy keyboard cable to me
As it's intermittent, I'm fairly sure Kee-Lo is right (he usually is!)
Is your Vaio still under warranty? Could be the best thing would be to open a case with Vaio-Link support.
:slight_frown:
kee-lo_
Hehe well I wish people would come back and say whether I was right or not, only 1 in 10 do
christian78
Hi !
Thanks for the awnsers !
My VAIO's warranty is over !
anyway !!!
I will oPen the keyboard because I would change the RAM Memory !
I hoPe I will find the cable that doesn't work !
( key "P" is one of the Problem
Many Thank's to you !
I will gave a feedback when I done it !
I hoPe you will helP me when the cable is not the Problem !
Ps: Excuse my Austrian English, Chris !
Good Luck Chris!!
:pray:
christian78
Hi Blencogo and Kee-Lo !
That's my feedback !
It was the cable !
my 1,25 GB RAM function ! ( 1 GB + 256 MB )
Very, very thanks to you ;-))))))))
Chris 🙂
Glad you've solved the problem Chris!
Told you Kee-Lo is always right - you have probably made his day!
:smileygrin: :smileygrin: :smileygrin:
