VGN-A297XP Memory Upgrade
Phil772
What is the maximum memory upgrade for the A297XP laptop?
I've read it goes to 1024 MB maximum in some places and others suggest 2048 MB.
Which is correct?
Phil :thinking:
16 REPLIES 16
Titane
Hello,
Have a look HERE
it says:
Memory Speed (MHz): 333
Memory Type: DDR SDRAM PC2700
Max. Memory (MB): 1024
Memory Size (MB): 512
:hugging: Titane
robpaxton
Have a look HERE
It says 2048MB :tongue:
kee-lo_
LOL thats VERY confusing - for me nevermind Phill :slight_frown:
Phil772
So you see my problem! :tongue:
Crucial sell 1GB modules too and seem to think its 2048 max.
Hmmmm :thinking:
kee-lo_
Crucial seem to know what they're doing.
Anyway why would you require 2GB? 3D work? Huge videos to edit?
robpaxton
I think it's 2048MB. If Crucial say it's 2048MB and it doesn't work then you can return the memory to them under their warranty.
kee-lo_
Yeah they're usually very helpful.
Phil772
I'll just go for the extra 512 for now anyway... good to clarify for possible future upgrades though!
:cool:
robpaxton
The 512s are better VFM at the moment. I'd personally give the 1GB chips a miss till the price drops a bit - unless I absolutely needed them.
