VGN AR71M Boot time / Hard Disk Replace
jamesmontado
Bought my vaio on friday (VGN AR71M) but the boot time is way slower than my old Acer 7720G. The new vaio has better processor and ram and graphics etc. the boot time is over a minte and a half and is generally slughish once in vista.
Did a compare of the windows experience rating and my old acer hard disk was 4.7 but the vaio is 4.5!! i know that the rpm on the vaio is 4200 and the acer is 5600.
Could this be the problem? Also i wanted to replace the HD anyway with a new one with higher cache (from 8 to 16) and higher rpm but they are all SATA 300 and the current drive is SATA 150.
I would like to know if i can still upgrade the harddisk or is there any other user with the same slow boot times?
Run vaio hardware diagnostics and it says everything is ok?
zuiindahouse
hi
i have ar61m and i did have that problem
but some windows updates and service pack one did the trick
and yes you can upgrade the hdd
i have 2 in mine the original 4200rpm 300gb and a seagate 7200rpm sata 300
very fast
just a small question, does ur laptop become loud and spin the fans
constantly if u connect it to a hdtv at higher resolutions?
im having this problem
cud u help me?
plus are u using the same nvidia stock drivers? the 156?
thnx
