I cant find audio driver (winXP) for VGN-FE41ZR ! Where i can download it?
i found solution! install microsoft kbxxxxxx update-file before installation driver!
Hello Virom and Welcome to Club Vaio,
If you are using XP instead of Vista, you have to use the driver of the FE31 package which is made for Vista.
But before as you said you must install the kb835221.exe which is in the package if I'm right.
\Audio\UAA High Definition Audio Class driver\
For the driver, I recommand to go in the device manager and to choose the driver to install yourself. You will find it here : \Audio\WDM\ in the folder you downlaoded.
The package is here : http://support.vaio.sony.fr/downloads/info/info.asp?site=voe_fr_FR_cons&url=Vaio/Original/FE3_Driver...
If you have another problem just ask. I did that for my vaio FE41M and it's working fine.
Hi virom,
please do not double post as it causes confusion and can waste peoples time..
See your other post here ..
