After being more than dissappointed with the performance with Vista. I decided to install XP
Dowloaded all the drivers and utilities
Copied the instructions and went to work
After installing the FINGERprint driver, The system won't shutdown
Also if the system goed on STANDBY, it hangs
Doe anybody know what to do?
Bios is updated.
THX, Harpert
