VGP-WKB1 wireless keyboard/mouse compatibility
EBraddles
Hello,
I'm considering this, but was wondering if it will be compatible with my laptop (VGN-FS215Z).
I can't see any reason why it wouldn't be, but it wasn't in a list of compatible models. In the same description however it said that it was compatible with all Vaios that came pre loaded with Windows XP. Mine did.
And so I am a little confused, and thought I would ask the community.
As the receiver uses default XP USB drivers, it should work with any PC running XP.
The VGP-WKB1 MANUAL says it works with any Vaio running XP except the PCV-LX series.
:slight_smile:
