VGX-TP2 'Multimedia Controller' driver for Win 7
clover90
I've completed a clean install of Windows 7 Ultimate on my VGX-TP2 and have one last issue. I can't identify and locate a driver for the hardware device 'Multimedia Controller', which I guess must be the on board Hybrid TV Tuner card as MCE tells me there is no TV Tuner Card installed. I could go back and install Vista and then upgrade - but it would be cleaner to avoid Vista (and the bundled Sony utilities, which I've never used).
I've tried DriverBoost - this is a help - but this can't identify the tuner card type.
Has anyone successfully done a clean 7 install?
Have swapped the original noisy 500GB HD for a WD Caviar Green e-SATA 2TB drive - which has made the unit virtually silent.
10 REPLIES 10
spud72
I know that this post is very very old but I have been searching for the answer to what tuner my VGX-TP2S has in it for a long time and this was one of the first posts i found so thought it would be good to post he answer here.
The tuner is an AverrMedia Hybrid TV Tuner Card M115S card Driver 3.3 - 3.3.23.103
I had upgraded from Vista and found the driver in Windows.old\Windows\Drivers so didnt need to spend hours searching the internet ( these cover the Multi Media Controller which was the Tuner and the Mass Storage Device which was the Texas Instruments PCIxx12 Integrated FlashMedia Controller
I hope that this helps someone out there.
