Vista driver for VGN-FE11H
silverkite
Hey,
I want to buy the vista ultimate. Do i need a driver for the SATA HDD? Can I use the XP driver for Vista? How to install? How to contain driver within Vista?
Thank you so much.
Kai
Resonate
Hey,
Thank you so much.
Kai
Have you tried using the VISTA Upgrade Advisor as it details everything which will & will not work within VISTA, It also details all drivers & software you will need to upgrade or change :wink:
