has anyone installed vista premium on the v3s??.. if so what is all this about new drivers.. do i in stall these when using xp before i install vista... alos woukld i have to upgrade my v3s or is it sufficient.
just thinkin cn i buy a educational version of vista as it is cheaper??
can u tell me what i need to do 2 install vista?
thx,, also will vaio zone still work
can any1 reply to this/?
I've just upgraded my V2M to Vista. I can tell you one thing; you need a LOT of memory, desite Vista telling me it'd be enough. So check that first.
As for drivers, most of the preinstalled XP drivers should work. But if you need updated drivers just check in the support section. Don't know if there are any for your model; there were none for the V2M.
Don't know about the educational version, but I expect it'd be very basic.
Vaio Zone will still work after you've reinstalled it.
Ex
thx 4 that,, can i just ask,, did u upgrage ur ram??
if so can u put 2gb of ram as it says only 1gb,, but on crucial it says 2gb i am confused??
I have now done this and can confirm that the V2M does accept 2GB RAM! :smileygrin:
