volume up/down buttons
Josh-2552
its not just my volume buttons, but my brightness, mute, and display buttons. Basically they decide not to work sometimes. Please can someone help me it's really anoying. and yes, i am folding down Fn :heart_eyes:
8 REPLIES 8
rich912
Which model of Vaio notebook do you have Josh?
Go n-éirí an bóthar leat
Josh-2552
VGN-FS415E (notebook)
rich912
I suggest that you try re-installing a few of the utilities. Go to Vaio-Link (Drivers and Updates) and download the pre-installed utilities for your model.
Extract the file and then install Sony Utilities (installer folder 1), Sony Shared Library (installer folder 2) and Vaio Event Service (installer folder 5) in that order followed by a re-boot.
You may find that it is necessary to repeat this procedure a couple of times before all works as it should.
Josh-2552
thanks rich, i'll try it now and let you know. btw, you work for Sony or something? if not you should ask for a job- you know your stuff.
Josh-2552
installing folder 5- do i modify, repair, or remove?
rich912
I would suggest remove and then re-install.
Josh-2552
had to redo a couple of times like you said, but it's working fine now, thx a lot
rich912
Your'e welcome Josh, pleased to hear that it is now working.
