VP update...
tommyb101
VP update...
Having updated sonicstage (from the eurolink) and the firmware update, I am still told I have to delete all songs or initialize the hard disk. How do I delete songs without being able to use sonicstage? or better yet, how to i 'initialize' the disk? Any help would be greatly appreciated!
Hey,
You can initialize your vaio pocket by inserting a pin or paperclip into the tiny hole on the bottom next to the part that connects the pocket to the cradle. pushing that button in should reset everything so be warned that you will loose all music on the player
