webcam
skimpey
webcam
i cant find the files or drivers for the motion eye camera on my vaio model vgn-cr11s/l i have vista home premium installed
rich912
Hi skimpey,
The original drivers package contains a ‘Camera’ folder’. Within that you will find a sub-folder VGP-VCC6 – these are the Sony Visual Communication Camera drivers.
Rich
Go n-éirí an bóthar leat
6 REPLIES 6
rich912
Hi skimpey,
Have you looked in the original drivers package for your model?
http://www.sony.co.uk/support/en/product/VGN-CR11S_L/updates
Rich
skimpey
hi rich
thank you for getting in touch,yes i tried that but still cant find anything
rich912
Hi skimpey,
Rich
skimpey
hi rich
ive fond it and i'll give it a go thanks for your help yeap found them and its worked once again thank you
Message was edited by: skimpey
flogger12345
Save that driver somewhere in your hard drive. You might need that in the future. http://imagicon.info/cat/12-13/vbulletin-smile.gif
rich912
You're welcome skimpey  :slight_smile:
Rich
