on the back of my A397xp there is a yellow socket, its like 3.5mm headphone socket but i read some where it was video out or something could some one help me out and tell where i can get a cable to fit?
thanks
Any good electrical retailers, example Curry's. Its just a video cable, like you have REd, whtie and yelloe, red and white are left and right sound, yellow is video.
so i don't need a sony one, a sony one is wired (from out to in the hole) red RCD
ground
yellow RCD
white RCD
i don't know if thats how normal ones are wired so is this one right?
No, all you need is a camcorder cable to tv, uses exactly the same 3 pole system they do.
