What memory to buy for a Sony Vaio FE31M
profile.country.en_NL.title
Carelino
I want to buy more memory I want to know if this one CLICK ON ME or this one CLICK ON ME will work on my Sony Vaio FE31M. I seem not to be able to find any information.
PS I live in Holland
Your FE31M can use either DDR2 PC5300 or DDR2 PC4200 modules.
PC5300 is slightly more expensive but is quicker. If you are replacing BOTH modules, this is the one to go for. If you are mixing it with PC4200 modules, it will work but only at the slower speed of PC4200.
It may be worth using CRUCIAL.COM because they GUARANTEE compatibility with your Vaio. Many of us have bought our memory at Crucial and there have been no complaints.
:wink:
profile.country.de_DE.title
seb21__
Kingsten Value Ram and Qimonda(Infineon) is always good. They follow the Jedec specifications and the Ram *should* work for sure on every board.
Carelino
Thank you very much for the tip. :slight_smile:
So you suggest me this one? CLICK ON ME
I searched and searched and decided on advice of you 2 to buy this one
Kingston SO-Dimm 1GB DDR2 PC2-5300 667MHz, 200p
