where can i get the HotKey/Fn Key utility? for S3HP
Marcos
I've looked and can't find or work out which thing to download to get HotKey functionality back
is it tied in with something else?
rich912
Hi Marcos,
Download the pre-installed utilities for your model from Vaio Link and extract the file. Then install the following in this order:
1 Sony Utilities (Installer Folder 1)
2 Sony Shared Library (Installer Folder 2)
3 Vaio Event Service (Installer Folder 6)
Then re-boot.
You may find that you need to repeat this process a couple times before the hotkeys work.
Go n-éirí an bóthar leat
Marcos
thanks, does this install other things too? the reason i got rid of a lot of things at the start is because of how bloated it all was. if hotkeys were just a single neat app i wouldnt mind it.
