Window contents while dragging
djwoody
I have enabled 'Display Window Contents while dragging' but when I restart my PC it reverts back to just showing the outline when I drag.
Any suggestions?
Chris
Resonate
Any suggestions?
Hi djwoody
Do you have any other System Utilite Tools installed which you have changed System Settings with as these will override Windows defaults.
Right Click on your Desktop > Properties > Appearance > Effects
If the box "Show windows contents while dragging" has rather a TICK or a colored box in it make sure it is a tick to enable.
Then OK > Apply on appearance > Then OK to exit
Hopefully this should work.
djwoody
Hi.
It definately is a tick to enable it so don't think this could be the problem...
Thalamus.
Champion
Hi djwoody,
When you start your Vaio, Go to start > Run, type regedit and click OK
Navigate to the following..
[HKEY_CURRENT_USER\Control Panel\Desktop]
Can you check that key below matches your registry entry please..
"DragFullWindows"="1"
