Hi.
I have a FE21H and when i shut down windows, it freezes on the 'windows is shutting down' screen.
Can anyone advise what is happening?
Chris
There was a thread recently which was the same scenario as this. From what I know, when windows "Hangs" on the shutting down screen it is because of a usb and power conflict. I had this problem with my BT USB Modem. You need to try and find what may be causing it.
Thanks. do you have the link to the post for me so i can find out a solution?
All sorted now. It was a problem with my Camera.
Glad you've sorted it.
I think this was suggested as a cause in your OTHER THREAD ON THE SAME SUBJECT
