Windows installing problems
Osing000
Hey all!
I hope anyone can help me out. I have installed Windows Professional with SP 2 on PCV-RS222, but appearentally, drivers of some hardware are missing! I have downloaded the preinstalled drivers of the site, but still the same problems...
The hardware that cannot be installed are:
- Multimedia audio controller;
- PCI modem and
- SM buscontroller.
Does anyone know what the problem is and how I can solve this matter? It would be so great if you could help me out!!!
Greets,
Gertjan
8 REPLIES 8
tonybeard
If doing a major change like that make sure you do the necessary research. Here is how to do it from James one of the masters here. BTW anyone seen the Jamester.
kee-lo_
Only on ClubJAMES Tony
Osing000
Thanks for the answers already! But now I have an additional problem: I formatted my computer and do not have my recovery CD anymore.......
Isn't it possible to download these drivers without the recovery CD or C:\Drivers map? I found out that my sound card is the 'Analog Devices AD1881A'. What I only need is a driver for this sound card and I am operational again...
So far, I checked out the sites soundcard-drivers.com and driverguide.com, with no luck. Other sites couldn't give me a good driver as well, so I am a little bit stuck.
Could you help me out?
Thanks for the help in advance!!
kee-lo_
Yeah it's very problematic - most of the drivers are on the DVD.
The only way you can get that is from eSupport
Osing000
Thank you for the quick respond! I will order the recovery CD from e-Support.
Have you downloaded BOTH the drivers and utilities from HERE ?
:thinking:
Osing000
Yes, and both didn't work....
Sounds like you will have to do battle with Vaio-Link Support after all!
Good Luck!
:wink:
