Windows XP Professional CD2
Are these cds stored on the vaio laptops? No CDs came with my laptop and I accidently deleted the pre-installed games and accesories like the calculator... but when I add/remove them it asks me for this CD2, if it is stored on the laptop where would it be located?
Thank you for any suggestions
Thalamus.
Champion
Hi quetzal_paradise,
When it prompts to insert CD2 try browsing to the C:\WINDOWS\I386 folder..
Resonate
Did you make your Recovery discs? If you did It will be on the System Recovery Disk as it has your i386 Folder & is completely accesable from here, But remember if you do use this Disk dont forget to take it out when you finish you dont want to boot up to a Recovery now :wink:
