I try to run the update and keep being told that the update is not for my version of WinDVD!
Any ideas?
You are not alone!
http://club.vaio.sony.co.uk/clubvaio/gb/en/forum/viewthread?thread=46094
I have asked Sony Support to have a look at it.
Hi 7hil,
Can you post the Current Version of WinDVD BD installed on your Vaio?
Are you still using the preinstalled Operating System?
Version 8.0 DXVA B08.416
The update is 8.0.8.416. I wonder if the "B" on B08.416 is messing things up? Should it be an "8"?
Yes I'm still using the preinstalled software. I haven't changed it or anything.
