Wireless Key in VGN-S3XP not working!!!
billpanou
My WLAN key in the S3XP is not respoding- do you know if I can fix this on my own or should I send it to the repair centre???
kee-lo_
Go to your router's page (usually 192.168.0.1) and go to wireless settings and check that the 26 alphanumeric code is the same as the one in the VAIO
