Hey guys,
I have a problem. I can't connect to my wireless network at home. I think the problem lies in the fact that the WLAN light isn't on after i set the switch to on. Is this light supposed to be on (all the time)? I enabled the WLAN adapter in network connections.The drivers of the 3945ABG pro card are updated to the newest version (v11.something). My laptop is a fe41s with vista home premium. What are the possible problems i am facing? I really need your help.
THANK U
The only explanation I have is your bluetooth light (blue light) lights when you switch the switcher on. To light the wireless lan light you should use the vaio control center. This program enables you to choose bluetooth/wireless lan/both of them when the switcher is turned on.
Good luck and perseverance.
Thanks FR57remi!!!!! That did it. Why didn't i think of that? I must have accidentally turned off the wireless when i first received my laptop. Many thanks.
