Wont play DVD's
daniel.allkins
Wont play DVD's
I have a vaio PCG-FR285M and have been trying to play a DVD.
Each time I put a DVD in the drive it spins but none of my DVD playing software picks it up, not even XP shows the DVD as being in the drive. Any ideas?
Dan
7 REPLIES 7
kee-lo_
This is becoming a too real problem these days with VAIOs, I guess the best thing to do is try and clean the lens.
If this doesn't work then let me know, I have a plan B
daniel.allkins
Will do, I'll try when I get home. (currently at work)
Dan
daniel.allkins
Ok so I have cleaned the lens a few times with a DVD lens cleaner. Played the cleaner CD fine, but its still hit and miss for the dvd to play.... I'm at a loss.
kee-lo_
Go to device manager (Right click my computer > properties > hardware tab > device manager) and right click the drive.
Click uninstall and restart your VAIO
daniel.allkins
tried that... sadly no luck... this is strange.
daniel.allkins
Ok... I have got a DVD to play, but others wont. Has anyone know why my vaio will play some DVD's and not others?
S.Bell
Hi.. Can you tell me your dvd model please, because I have the same problem with you... (you can find it by pressing right klick on dvdrom\properties\hardware...).
