wont update
pmpmac
wont update
Hi All, i have a vaio notebook VGN-N21M and when i try to update i can update all the various updates except the Vaio update and iam stuck on version 3.0.00.11180 which was installed on my laptop the day i bought it 2 months ago,when i download the update it goes through the install process yet when i follow the instuctions to check to see the new version number its always the old version,can you help thanks
Thalamus.
Champion
Hi pmpmac
Does this thread offer a solution..
pmpmac
Thanks Thalamus your link to the thread worked a treat,once again thanks for taking the time to find the solution,
Pmpmac :wink:
Thalamus.
Champion
You're welcome Pmpmac, it was easier to find this time though as I had posted the solution.. :slight_smile:
