z1sp sudden noise, possibly fan?
paradoxchild
hello, over the last week or so my z1sp has started making a noise when (im assuming) the fan speeds up. its not a screech but more of a chug. a bit like a trail bike motor at low rev if that helps lol
its not a constant noise so i can only assume it is linked to the fan. how do i go about cleaning inside my notebook though? there is only a small vent on the underneath. is there a safe way to open it to see if it is clogged with dust? or dont you do that with laptops.
any tips?
thanks
james
8 REPLIES 8
jumpsuit
Hi there!
The first course of action I would suggest would be to download MobileMeter to check cpu temperature as there is a possibility that your cooling vents or fan are partially clogged.
Secondly you could try clearing dust and debris from the vents with judicious use of compressed air from a safe distance as too close can damage your fan.
Hope this helps.
mobilemeter
paradoxchild
ok thanks ill download that.
i have a set of computer adaptions for our hoover...would they still be too powerful?? there are some small nozzles /brushes
jumpsuit
Always be carefull when thinking about using the hoover. Officially they're frowned on, due to static electricity issues.
I've used one on my desktop, but I can't really advise you on doing the same on your 'slim' notebook. Its your call.
paradoxchild
hello. i downloaded mobilemeter and cpu temp (so far) has been around 48-51c..which doesnt seem too bad ??? ive not done the hoover , but i havnt any compressed air either.
paradoxchild
hmm it went from 48 to 62 when i left it idle!!!!
kee-lo_
Try Maplins tomorrow
paradoxchild
for the compressed air?
kee-lo_
Yep
