Duplicate playlists on NWZ-A15
hirobmay
hi, I have duplicate play lists on the device of my NWZ-A15.
The medio go software does not have duplicate playlists, so I do not know have to get rid of them?
I'm currently using the 16GB on board memory, but I have added a 128GB micro SD and have used the music on there, but in swiched back to the internal memory in an attempt to fix this.
Anyone no how to get rid of the duplicates?
Rob.
Sonyvores
It happens sometimes; don't know why, but the easiest way to do it, is to use windows Explorer to browse teh Walkman folder. You'll find the playlist files under the Music folder, erase one and there you go 😃
hirobmay
Thanks,
I did try this and some of the duplicated playlists were seen in Windows, but some wern't duplicated, but are still duplicated on the device?
Any other ideas?
Rob.
Sonyvores
Then try this:
*Delete playlist via media go (take care to delete playlist only but keep music files on device)
*Eject & close medigo
*Reconnect & use windows to delete extra m3u playlist files
*Disconnect & check on walkman (you shouldn't have any playlists this time)
*Use media goto import playlist
Now it should be fine
