Sony SRS-X2 speakers - simultaneous play
I recently purchased a second SRS-X2 speaker to complement the sound of an earlier SRS-X2 speaker purchase. In this respect, I had hoped to be able to use both speakers contemporaneously, either in the same room, or separately in different locations in the house. Although the bluetooth device (Apple I-Pod) seemingly recognises and connects with both individual speakers (i.e. "connected")  - sound (playback) comes only from one of the speakers at the given command.
My question: is whether or not contemporaneous (bluetooth) playback via the two SRS-X2 speakers is possible?
I would be grateful for any advice /feedback if there is a solution to this problem.
Thank you.
Hi there
I the features you are requiring can be done using an app called 'SongPal'.  See:
http://songpal.sony.net/en_ww/help/basic01.html
http://songpal.sony.net/en_ww/help/basic03_3.html
However, I have just looked at the compatibility list of SongPal and cannot see any mention of SRS-X2:
http://songpal.sony.net/en_ww/device.html
So unfortunately it doesnt appear that you can do this on the SRS-X2
