MEX-N4100BT
Cannon420
MEX-N4100BT
Does anybody know how to stop this incar sound system from prompting me to 'open app' every time it turns on? I don't find the app very useful for an incar stereo and would rather not have to skip past this step every time I use it. Thanks
Hi there
I am assuming that you are referring to the SongPal app?
A couple of suggestions:
  • Try removing the MEX-N4100BT from the SongPal app
  • Unpair the phone/device from the MEX-N4100BT and see if that has any effect.
  • According to Sony's FAQ - HERE - Ensure you have the latest firmware installed.  See HERE
Other than that, im not too sure on what else to suggest.  A quick search on Google indicates this is an annoyance for others too.
Hi there
Cannon420
Thanks for your suggestions, I will give them a try!
