MZ N510
victim311
MZ N510
Simple question but I cannot negotiate the Sony website to pose this question so I thought I'd try this forum.
I recently bought a portable minidisc player/recorder MZ N510 without an AC mains charger. It seems that I need one of these in order to record stuff. The nearest thing I have been able to source is a charger for a Sony minidisc player
AC-ES305. It has all the specs in terms of input/output voltage, polarity etc but I am unsure if the small plug will fit my model. The seller doesn't know. Can anyone advise, please?
Peter_S.
Genius
Usually the plus should fit since the size is related to the voltage of the power supply.
Please try carefully to insert the plug.
Peter
Peter_S.
Genius
Peter
victim311
Sounds good to me. Thank you, Peter.
