Sony Discman cd-player D-E445 battery
profile.country.SE.title
fredriksolborg
Hello,
I have a perfect Sony Discman cd-player D-E445 except for the rechargeable dual battery that is dead.
Do you know where I can buy a replacementbattery?
Thanks a lot in advance and have a nice weekend :slight_smile:
Best regards Fredrik (in Sweden)
Peter_S.
Genius
Hi Frederik,
You can use 2 AA-sized batteries as well.
Peter
Peter_S.
Genius
Hi Frederik,
Peter
fredriksolborg
Thanks for the answer, but I also want the function to be able to charge the rechargeable battery directly in the cd-player.
Pentium_Gladio
Specialist
The rechargeable batteries for the unit are BP-DM10 or BP-DM2, and you can find it in the manual here on page 2. You can check for them online if they are still available.
Regards,
Pentium_Gladio
