Nw a55l flac
Inoneear
Nw a55l flac
Hi. I've download FLAC files from Bandcamp, moved to a micro SD and inserted in to the A55L to playback. Some files are shown in the Hi-Res folder on the device whilst others are not. I can see some have saved at over 990 kbps while some are just under so not classed as hi-res.
Is this common? Is it just the way the record label compressed the audio file? I assumed FLAC was Flac but I guess MPs is variable as well.
Tags (1)
Bat_Rick
Hi Inoneear,
If you see the file format on your PC as standard one (not high resolution), this means this is the way the record label compressed the audio file.
Sonyvores
U've probably bought CD quality compressed in Flac.
