NW-A55L - is there a way to disable the database rebuild every time it starts up?
QSwitch
I bought the new NW-A55L and I noticed that it rebuilds the database every time it starts up.  That's fine when the database is small, but mine is going to get relatively big - I'm at least going to have around 230GB which looks like it's going to add at least 30 seconds to the start-up.  It's not as if there's any good reason to assume the database has changed every time the device is turned off, so I'm hoping this isn't a major design gaff and that it can be turned off and rather done on demand, as the A105 allows.  Is it possible to disable this rebuild on start-up?
Pascale_F
Moderator
Hi QSwitch,
I'll look into this for you and see if I can find anything out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi QSwitch,
This is a normal operation of the Walkman as far as I am aware and it cannot be disabled.
Cheers,
The_Black_Rose
KevG32
Great question and if it’s not possible then maybe Sony could build this into a firmware update. I’ve got the ZX300/WM1Z and they are the same. I’ve got 300Gb of flac files and would love to skip the rebuild every power up.
