Walkman Playlist
Bootsy2012
Walkman Playlist
Can anyone know how to create/tranfer Playlist with Content Transfer?? Thanks
Tags (3)
@1457389300013388
Hi
I've been trying to transfer a playlist through windows media player (version 11) for hours and hours with no success, so I tried using iTunes and it actually worked! Just create a playlist on iTunes and do the drag and drop thing with the content transfer and it should work :slight_smile:
Hope this helps
@1457389300013388
Hi
Hope this helps
Maldoc12
Hi
I cannot transfer a whole playlist. The individual tracks transfer but not as a seperate playlist. E.g. classical v pop.
They just merge with everything else on my walkman. I can only seperate them out using bookmarks.
Please help
