Nw-zx507 how big is the sdcard?
TaraJBurdette53
Sonyvores
There is no sd card in teh package but if u'rs askign abot size compatibility, there is no restriction. I 'm using a 1To sd card and it works flawlessly 😃
Joe_Dohn
Specialist
I agree with Sonyvores, and the specs confirm it supports Micro SDXC, which means up to a theoretical 2 TB cards if I recall correctly.
Hope this helps!
- JD
