WH-CH710N can't change volume
Cah_hac
Hi I cannot use the volume button on my headphones to change the volume, all I hear is a loud double beep then the music keeps playing as it was before. Any ideas?
Joe_Dohn
Specialist
The headphones' specs confirm they support AVRCP, which is the profile responsible for controls over Bluetooth, so might be the device you have connected to them doesn't support it, is in some way not compatible, or just glitching.
Joe_Dohn
Specialist
Try using a different device (phone, laptop, etc) and see how that goes.
