WH-1000XM3 Fast Charger
compyy
Hello,
I just bought WH-1000XM3 3 days ago. I am having strange issue if i try to charge WH-1000XM3 with Samsung or OnePlus 6T fast charger, it doesnt charge (Red light turns on and then turns off after 10 seconds) i have to connect it to my PC only to charge? why is that so? it should be fine with my mobile charger ??
Yasir
23 REPLIES 23
scpritc
Using the supplied cable, because that seems to be the issue?
---------- Scott
Wingchaser
I also own the OnePlus fast charging adapter. Theres no problem with the wire. It's just the adapter itself. In fact the headphone fastcharges on anything that is not a fast charging adapter. I did have the same problem you had. But then I changed to a HTC adapter which worked perfectly fine. It just maybe that the Samsung and OnePlus which are the most powerful fast chargers around are too high of a voltage for the headphones so it rejects it.
I recommend using an average adapter and try not to make it a "fast charging" one.
Par134
Hi!, was there any real solution to this? I also encountered this problem. Used to charge it with the charger for my iPad Pro, one for regular ipad and also with my samsung charger for samsung S7 and with USB-charger for lenovo surfpad. Also with general USB-charger for lights to my bike. I went by the guidence in the information given with the Headphones and downloadable guide from Sony, according to which mentioned ones qualified.
But now it seems random, from my Mac computer it seems to charge fine. But from mentioned USB chargers it gives red light for a few seconds and then goes of and no charging occurs. It behaved like this, but then suddenly it was ok and got fully charged a couple of weeks ago. And now it’s the same, It worked on one occasion, but mostly it doesn’t, but with the computer it seems fine.
But I cant bring my stationary around, so what to do?
clydebest
Same with mine had it not charging for hours with a One Plus 6T charger... as with others Red Light comes on then after a few seconds it goes out .. plugged into Desktop and it charges .. found a old USB adapter and it works fine but .. strange the Sony Adapter is fast charging.
stulou
Only chargers rated between 5V / 0.5A - 5V / 1.5A will charge the headphones safely and efficiently. I have the OnePlus 7T Pro and the charger is rated 5v / 6A. I wouldn't use that to charge another phone let alone these headphones.
Par134
For sure 6A seems a bit high, but the manual states it requires an usb-adapter that can deliver 1.5A or more.
stulou
The online Help Guide for them clearly states a USB AC Adapter of 0.5A (500 mA)
https://helpguide.sony.net/mdr/wf1000xm3/v1/en/contents/TP0002289867.html
However, I have read elsewhere that up to 1.5A was OK which is what I use and so far, so good
IcanFeelit
According to this page https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703124.html :
"A commercially available USB AC adapter capable of supplying an output current of 1.5 A or more
(If the output current is less than 1.5 A, the charging time will increase, and the music playback time after 10 minutes of charging will decrease.)"
Fontmeister
One year later after my initial post I’m still using the same charger which takes about 1 1/2hrs from empty to a full charge, I have not had a single problem charging my XM3’s. My P20 Pro SuperCharge is rated at 5V 2A and/or 5V 4.5A.
Your link points to earbuds with a confusingly similar name (WF-1000XM3) so it looks like 1.5A+ after all.
