mac address problem
gooeylouis
mac address problem
hi all
just brought my sony tablet s 16gb wifi and filling out registration form but it keeps saying my wifi mac address is invalid, ive taken the mac address from my modem and also gone through the network settings and found another mac address by going to properties and hovering over the  connect using bar and a mac address comes up, sorry new to all this and probably not explaining it to well. i googled how to do it and followed the instructions but my tablet wont accept either one.
any help would be great
lemurville
Hi there,
Tap on the icons in the bottom right hand corner of the screen. Then taap anywhere in the top rectangle that appears. Then settings -> about tablet -> status.
Et voila!
lemurville
Hi there,
Et voila!
profile.country.fr_BE.title
bennybuche
You can also find the wifi MAC address via the 'Wifi Finder' app. The MAC address is under the 'About' button (upper right corner) :wink:
gooeylouis
hi
thank you for the replies,im all set up now.
many thanks
