passcode for the tablet s
tommysmith1980
I have the 9 dots as a passcode on my tablet, but I just want the padlock now where you can swipe across to the cammera, but I cant get rid of the 9 dots, any advice please.
Thalamus.
Champion
Hi tommysmith1980,
yes you can but your tablet will not be as secure..:smileywink:
Touch on Apps & Widgets top right..
The open settings..
Then select security..
Touch on Screen Lock..
Then enter your nine digit pin code & touch continue..
Then touch on Slide..
To check gently press the power bttonto place your tablet into sleep..
Then press the power button again to wake your tablet from Sleep & you should be presented with the Padlock icon..:smileyhappy:
Thalamus.
Champion
Hi tommysmith1980,
The open settings..
