Size of micro SD card
benresipole
Sandisk has announced the development of a 128Gb micro SD card. Will the Tablet Z be able to make use of this larger card?
rich912
The reviews I've read all say it supports up to 64GB.
Rich
Go n-éirí an bóthar leat
profile.country.nl_NL.title
breedBenR
it will depend on the filesystem (formatting) of the sdcard. The announced compatibility update to 64 Mb suggest more filesystems to be supported now than for the S-tablets. wait until release and it will quickly be clear.this also matters for opening files larger than 2.3 Gb and so on. (long HD films)
profile.country.no_NO.title
andesten
Does the Tablet Z support both SDHC- and SDXC-cards?
The specification page here at Sony only says SDHC, but that isn't right, or is it?
