With a cracked screen - how can I transfer contacts etc to an iPhone
Cirrus99
I cannot get the app to transfer my contacts and other data held on the phone to an iPhone, as the crack stops me entering commands. Can anyone suggest how I might be able to do this? Thanks
Jonas
Master
Hi @Cirrus99, sorry to hear about what has happened to your tablet. Slightly_frowning_Face
If the screen is still working and showing the normal UI, you can with the help of a mouse and a OTG adapter maneuver the screen using the mouse cursor.
I have written a guide about this here at our forum that has all the steps / information that you need so I recommend that you take a look at the guide! Slightly_smiling_Face
/t5/FAQ/How-to-perform-a-backup-transfer-data-when-the-touch-screen-isn/m-p/1212631#M34
Let me know if that helps!
