Charging so slowly up to andorid 10
kisana
Hi!
I updated yesterday. Battery charging is too late My charger is a fast charger up to 20V. I hope this will be fixed by a quick update
16 REPLIES 16
Tony-TBB
My xiaomi powerbank 3 (pd 45w ver) cannot charge my phone via type-C connector after Android 10 upgrade. Type A connector works fine.
Really weird.
Yekollu
The current line up of Xperia phones  1 & 5 (and almost all Android phones in the future) do not support fast charging instead we have something USB Power delivery. The phone will charge with normal speed when you use a Fast Charger
Tony-TBB
But the same powerbank and the same cable worked perfectly in all previous Android 9 versions.☹️
RuneJ
By using the included charger to the phone, I notice no change/difference in charging behaviour from Android 9 to Android 10. Smiling_Face_with_Sunglasses
Tony-TBB
Does it support PD charging?
My problem only appears when using xiaomi power bank.
PD charger using AC power still works as fast-charge.
RuneJ
You will probably have to check with Xiaomi to verify if it supports appropriate PD-protocol, etc.
xenite5
I use original Sony chargers from my previous Sony phones all original and having the same issue. The only thing that works is the charger I have got with Xperia 1 which is nonsense.
I never use other brands or non official chargers or cables. And it was working perfectly with android 9.
PsYCOW
Yes but people are having trouble with PD with android 10, i have issues with my power bank since the android 10 update.
PsYCOW
The xaomi 3 power bank does support pd and qc3.0 but since xperia 1 updated to android 10 something has been broken, the power bank doesn't update so its the sony.
