Is this an UI bug?
akmtshun
Is this an UI bug?
The Android 14 has been successfully installed.  When Settings > System > Developer options > Smallest width is set to 600 dp or larger, the Xperia Home crashed and the 3 buttons navigation bar disappeared.  Will there be a fix for the issue(s)?  Thank you.
HannahEd01
Community Team
Hey akmtshun, you shouldn't be tampering with all developer options BTW. But what's the model number of your phone?
akmtshun
Xperia 1 V (XQ-DQ54). It's easier to navigate the Google Chrome browser after setting the smallest width to 600 or above (i.e. full-screen mode) -- it's easier to open a new tab and close/refresh a tab.
HannahEd01
Community Team
Hey akmtshun, why do you have the need to use it? Is there an issue with your phone?
Anyway, try these basic fixes: https://www.sony.co.uk/electronics/support/mobile-phones-tablets/articles/00232845
