PS4 remote play availability?
XuX
I own an Xperia 1 and I'm trying to install PS4 remote play from Google Play. Unfortunately, it turned out that this app doesn't support my device. I'm wondering if it really works on Xperia 1. I bought my device from China and it's a J9110.
BTW, I tried to download the apk file from apkmirror but it doesn't install.
RottenFoxBreath
Enthusiast
Yes it does work, and works quite well.
It may be that it's not supported in your market(China), but it should be.
RottenFoxBreath
Enthusiast
Hip5hooter
I wouldn't bother anyway it is laggy.
Tomas6
remote play is also avaible for different phones like Sony Slightly_smiling_Face - https://vosveteit.sk/sony-spristupnuje-sluzbu-remote-play-pre-vsetky-android-zariadenia/
