I own an Xperia 1 and I'm trying to install PS4 remote play from Google Play. Unfortunately, it turned out that this app doesn't support my device. I'm wondering if it really works on Xperia 1. I bought my device from China and it's a J9110.
BTW, I tried to download the apk file from apkmirror but it doesn't install.
Solved! Go to Solution.
Yes it does work, and works quite well.
It may be that it's not supported in your market(China), but it should be.
I wouldn't bother anyway it is laggy.
remote play is also avaible for different phones like Sony
- https://vosveteit.sk/sony-spristupnuje-sluzbu-remote-play-pre-vsetky-android-zariadenia/
