Something to learn from the MK ii
Gilgameshuk
It seems the sensors that are letting this phone down are BOTH of the samsung sensors, that is these are the most that people complain about.
The main and ultra wide sensors are Sony but the telephoto and self cam are Samsung, why on earth I have no idea?
Sony if you wish to save cost on these sensors, then DONT buy samsung, why not use the lower cost and spec of IMX? Or build a new sensor JUST for sony like you did with the main one?
I hope you learn your lesson with a future mk III and not to use INFERIOR quality Samsung sensors, no matter how much money it saves.!
 I will stick with my Xperia 1 (original) until the MK II has had time to stabilise. As now that the software mk ii) has not matured and the only thing i find (on the original xperia 1) issue with is ZERO stability at 4k on the main lens (fine on ultra wide)
Gilgamesh the first ONE and ONLY King
4 REPLIES 4
BBEN66
I thought  the the back camera system has only one Sony sensor, the main 24 lens and the other two are from Samsung. Must check with Aida.
Gilgameshuk
nope
selfie is samsung
back main is sony
telephoto is samsung
ultrawide sony
BBEN66
Ok, still two "enemy" lenses :wink:
Gilgameshuk
exactly
