Transferring music to Xperia 1 internal storage using Xperia Companion
Blumine1818
Hello
I am saving music to my Xperia 1.
Using Xperia Companion, I only have the option of transferring to memory card using Xperia Companion.
Am I missing something?
profile.country.PH.title
MarlonUk1
if you use the supplied usb cable and connect it to a pc, it will show up as a mass storage on your pc. just check the prompt on your device to connect
MarlonUk1
another option is to use the built in file explorer, there is a dedicated app called FILE. and the other one is burried in the settings
