Sony Xperia 10 IV android security update
hehduda
Hi all,
my sony xperia 10 IV (unbranded, sim-lock free) arrived on 08.july.
Up to now there was no android security update. So I'm on 1 april 22.
Where can get this update from?
profile.country.PH.title
MarlonUk1
hello @hehduda
all of the xperia 10 IV softwares are updated to 65.0.A.0.1094 with security patch 2022-04-01
11 REPLIES 11
MarlonUk1
hello @hehduda
updates are released by region.
try to check your latest available update for your device at Xpericheck.com
hehduda
Hi @MarlonUk1 ,
thank you for your answer,
i checked my device following your link. But  the sony xperia 10 IV XQ-CC54 i've got, is not listed at Xpericheck.
I'm in touch with Sony support and they're investigating in this case.
I'll post the result here as soon as it is available. But (according to Sony support) this will take a few days.
MarlonUk1
hello @hehduda
hehduda
Hello @MarlonUk1
I think so too. But todax is 21st of July so the update to the June patch should be possible.
As mentioned above I'll wait for the answer from support. In the meantime i accept your answer as the solution.
hehduda
To whom it may concern
I got the reply from Sony support today. According to this, the Sony Xperia 10 IV is up to date with the Android security update from 2022-04-01.
I don't know what to make of this now, but I've been using Xperia since the Z1 and nothing like this has happened before.
SpitfireMk
I'm from Spain and today I received the update 65.0.A.0.1127.
The security version is now 1 June 2022.
hehduda
Hi @SpitfireMk
Thanks for the info! Updating...
HannahEd01
Community Team
Hey hehduda, did you get the update?
hehduda
Hi @HannahEd01
yes, I've got the updatevto build 65.0.A1127
