Android 12 update - battery drains to 0% over night
profile.country.NO.title
haradl
Xperia 5 II.
I keep battery charge 20-80%.
Had no issues with it.
Updated to Android 12, two days ago.
Now I've overslept two days in a row.
Phone has drained over night and turned OFF.
(I put the drained , turned off phone on the charger and ... whoops.. no battery care. 100% charge. Android 12 update has taken more life out of the battery the last 2 days than 10 days normal usage with Android 11!)
Please advise!
Lord_viridis
I would recommend backing up your files using Xperia companion, then perform a "repair installation"
Once complete, restore using the previously made backup.
Once complete, reboot phone and when loaded, press and hold the volume up and power button until you feel 3 vibrations. Then restart the phone.
This should clear out any errors and will clear any caches made that may hinder the creation of new caches using the android 12 apps.
Piscie
Community Team
Hey @haradl, you can also try the following before the software repair: Tap on Settings - Apps - See all app - Tap on the 3 dots on top right corner - Show system -  System UI App - Storage - Clear cache and clear data - Return back - Tap on Force Stop, followed by a forced restart (Hold the power and Volume+ simultaneously)
