Battery Size?
Yekollu
Battery Size?
What is the Battery Size of Xperia 5? Official Specs show 3140 mAh but apps that show the size of the battery (ampere etc) show it to be 3000mAh? Was wondering if all the apps are wrong or Sony mislead with the battery size or if the battery is starting to degrade already?
5 REPLIES 5
profile.country.NL.title
Strampke
Make a phone call.
*#*#SERVICE#*#*
Go service tests
Go Battery Health Test
Yekollu
Thanks.... It says 3051000 uAh, approximately 100mAh than as advertised...
How much does it show on yours?
Strampke
I have Xperia 1
Maybe someone else is willing to take a look.
However the result is less important that having good habits.
Check 'consuming apps' in settings.
Don't install everything, keep your machine lean and clean.
Don't discharge to <10%
Don't charge to > 90%
Your battery will reward you.
VaioXperia
Battery health test for me says 3130 mAh, after aprox. 6 weeks of usage. It's rather convenient to know the battery status. Does it decrease over time?
Strampke
Every battery decreases over time.
I recently read a report about electric cars.
2 - 3% per annum, with frequent quick charging up to 5%
Don't go to the edges with your phone's battery, that helps for battery life.
